Partlist
Exported from schematic.sch at 2008.10.11. 11:49:42
EAGLE Version 5.0.0 Copyright (c) 1988-2008 CadSoft
Part     Value          Device          Package      Library        Sheet
C1       220mfd         CPOL-EUE2.5-5   E2,5-5       resistor       1
C2       22mfd          CPOL-EUE2.5-5   E2,5-5       resistor       1
C3       100n           C-EU050-025X075 C050-025X075 resistor       1
D1       1N4148         1N4148          DO35-10      diode          1
D2       1N4148         1N4148          DO35-10      diode          1
IC1      AT90S2313P     AT90S2313P      DIL20        atmel          1
IC2      7805           78XXS           78XXS        v-reg          1
K1       351            351             351          relay          1
LED1     red            LED3MM          LED3MM       led            1
Q1       BC547          BC547           TO92         transistor-npn 1
R1       47k            R-EU_0204/7     0204/7       resistor       1
R2       10k            R-EU_0204/7     0204/7       resistor       1
R3       220            R-EU_0204/7     0204/7       resistor       1
R4       4k7            R-EU_0204/7     0204/7       resistor       1
R5       10k            R-EU_0204/7     0204/7       resistor       1
SL1      12V            M02             02P          con-amp-quick  1
SL2      Keypad         M07             07P          con-amp-quick  1
SL3      LCD            M14             14P          con-amp-quick  1
SL4      ISP            M06             06P          con-amp-quick  1
SL5      Jumper         M02             02P          con-amp-quick  1
SL6      Buzzer         M02             02P          con-amp-quick  1
SL8      Door1          M03             03P          con-amp-quick  1
SL9      Door2          M03             03P          con-amp-quick  1
SL10     Clk            M02             02P          con-amp-quick  1
